Nawfmemphis
Memphis TN
5.7L
*first post*
I just installed two kicker cvt 12” on a kicker cxa 800.1 in my 2016 ram 1600 big horn 4x4 I got last weekend, using the pac ampPro device. And it sounds like pure D ****! The bass is muffled and no matter what I do I still kinda get highs coming thru my subs. And when I turn it up past half the bass is super weak. This same setup sounded amazing in my f150 with the pac ampPro. So I would appreciate if someone could hopefully help me understand wtf I’m doing wrong here.
platoon2063
v6 eTorque
Need to double/triple check the following:
Input level button.....out
x-over knob......probably start with it straight up and down and then adjust from there
check your sub wiring.....is it correct for the type of subs you have?
BTW, are those subs 2ohm or 4ohm?
Nawfmemphis
Nawfmemphis
Memphis TN
5.7L
Thanks man yea I checked all those things. I’m just gonna scrap the 8.4 uconnect Tuesday when the new radio and maestro box gets here. I literally took it all out of my f150 Monday morning and put it straight into the ram Tuesday left all my amp settings the same.
woojyee
Nebraska
Hemi 5.7 eTorque
I use the AMPPro and it provides a clean signal. My system sounds amazing. Assuming you are using the correct AMPPro for Ram, I would check to see if the dip switches are configured correctly and, if the radio is programed per the instructions. additionally, double check to see if the RCAs are plugging into the correct outputs. If not, you will not get the proper output from the unit.
Nawfmemphis
Nawfmemphis
Memphis TN
5.7L
Yea I just uninstalled and returned it. After checking software and dipswitches I figured it was the unit. I’ve been installing sound systems for 20 years so I quadruple checked everything. I just said screw it and ordered the “10 floating pioneer NEX head unit and the idata link maestro module and dash kit. Should be here tomorrow evening
kirk35
Ocean Springs, MS
6.7 CTD Tradesman
Do the 2016 1500's have ANC? I have the AmpPro AP4-CH41 R.2 and my system sounds great.
woojyee
Nebraska
Hemi 5.7 eTorque
Well, that's significantly more $$$ but, I suspect you would get more features and tuning control with an aftermarket head unit. I have a TosLink going from the AMPPro to a JL Audio Vxi 800/8 and the system was tuned by a pro with the MAX. It sounds incredible.
Nawfmemphis
Nawfmemphis
Memphis TN
5.7L
Alright everybody I put in the floating 10” pioneer nex display and now everything sounds great subs shaking the entire house did my time alignment and everything sound sloping and all. Didnt rewire subs nor adjust amp from my previous truck I took it out of so I’m thinking it was ampPro. I also used all maestro idatalink equipment this go round
Nawfmemphis
Nawfmemphis
Memphis TN
5.7L
Only thing is I gotta figure what’s going on with my back up camera it shifts to the screen but doesn’t show up now
Nawfmemphis
Nawfmemphis
Memphis TN
5.7L
Found shortage in the camera wire from new radio harness everything works now
