Lift with Stock Wheels and Larger Tires?
Chris0218
Levittown
Just got a 2019 Laramie. It came with 20x9 wheels and 275/55R20. Any recommendations on a 35” tire to put on the stock wheels? Also, can I get away with a 4” lift with no rubbing?
Thanks. Long time pickup truck owner, but novice to lifts and wheels.
Wandell
Cummins 6.7
It depends. A lot of suspension lifts require wheels with less backspacing than the stock wheels.
Wes Creamer
Dudley Ga
This was before my current set up. 2019 bighorn 4x4 with sport package. 2in Rough Country leveling coil spacer, stock 20x9 wheels, 35x12.50x20 Toyo Open country m/t. Everything was installed by dealership, and I had no scrubbing whatsoever. Upgraded to bigger leveling kit to maintain same ground clearance after I installed my brush guard. Currently running a MotoFab 2.5in coil spacer with the same tires and wheels. Initial set up/current set up pics, current is with brush guard. Hope this gives you an idea. IMG_0126.jpgIMG_0362.jpg
olyelr
Kewadin MI
This was before my current set up. 2019 bighorn 4x4 with sport package. 2in Rough Country leveling coil spacer, stock 20x9 wheels, 35x12.50x20 Toyo Open country m/t. Everything was installed by dealership, and I had no scrubbing whatsoever. Upgraded to bigger leveling kit to maintain same ground clearance after I installed my brush guard. Currently running a MotoFab 2.5in coil spacer with the same tires and wheels. Initial set up/current set up pics, current is with brush guard. Hope this gives you an idea. View attachment 162353View attachment 162354
I like!
The 2.5” level looks like a bit much IMO. I would slap on a 1/2”-3/4” spacer for the back springs :favorites13:
Scottys19
Wittmann, Az
5.7 ETorque
I really dig the look! I was wanting to do the same thing, use my stock wheels after I lift it. Looks great!
Mzajac0905
Lapeer Michigan
Do you have any pictures gun siting the truck? You have the same truck as me, I’m debating about 35s. I have the 2” level on front. Same rims 20x9.
You said there is absolutely no rubbing?
Dewbo
3.5” front and with the heavy up graded Rear springs 4.5”…..stock wheels, nittos that spec out to 34.75 x 11.5 no issues…..C7EDB541-01DF-4A28-8883-DD7776605044.jpeg
