Hurricane durability questions?
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
No oil dipstick? What is the thinking behind this..........kind of like to know the amount of oil consumption and making sure level is proper. I really don't like sealed transmissions without dipsticks either. Makes filling to the correct level a bit tricky, at least in the Titan Jatco 9 speed.
I know it seems strange to not have a dipstick. But as an Audi owner I've gotten used to it. Many european brands haven't included dipsticks for years. On my Audi I check the oil level using the infotainment system. There is actually a dipstick tube (used for oil extraction when the dealership changes the oil), and there are aftermarket dipsticks available for most of those cars that come without them. Seems like a bigger deal than it actually is.
TruckNut
Tennessee
I had a 2018 Mini Cooper like that and never quite trusted the "electronic info" on oil level, but I never had a problem with it. Just old fashioned I guess and like the visual of seeing oil on a stick, lol.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I'd be more worried about it after the vehicle is several years old or has high mileage. Like anything else electronic, it's only as good as the sensors providing the data. Which is why I bought one of those aftermarket dipsticks I mentioned earlier for my Audi LOL.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Exhaust manifolds on a turbo will need to far more robust than what was ever used on the Hemi.
And will far more difficult to change out as well...
I've read that the exhaust manifolds are cast as part of the cylinder head on at least one of the two variants of the Hurricane. I haven't seen one for myself to confirm this though.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Why are people concerned about trans fluid levels? Is your trans leaking? If so, get the leak fixed. If not, then the fluid level will not change. It's a sealed system.
Riccochet
You might be thinking of the pentastar 3.6.
But looking at photos of the 3.0 Hurrican you might be right. It looks like the turbo's are bolted directly to the head. They should spool pretty dang quick like that.
Bighorn John
Greensboro NC
I’m with you on keeping it as long as possible. I Have 2022 Bighorn non-E torque and hope it lasts as long as my older brothers 1st Gen 2003 Hemi. He just hit 351,000 and had first issue internally with a broken valve spring on original motor and trans. Some of the new tech is nice but some is so new it needs bugs worked out before I’d even consider them.
Docwagon1776
Midwest
If you never unseal your sealed system, your point is completely valid. If you intend to open it for maintenance, less so. Checking a dipstick under the hood with a 'cold' and 'hot' mark is significantly easier to verify correct fluid levels after maintenance than getting under the truck, using a scan tool to verify temperature range while checking it, etc.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
Is it working hard all the time, though? Given the peak power and where it comes in the curve, and the fact there's a bajillion people running these trucks with an *NA V6* that makes significantly less power, why would it be working hard constantly? Seems like the pentastar would be the one working hard all the time since it needs to spin more to get into it's power range and it's got less power to begin with.
So much this and exactly where I'm at. I don't expect to need a truck for 10 years or more at this point and don't know I'll ever buy a new one again. Not because of the motor choice but because of the increasing risk of mandated 'safety features' like automated driver monitoring that may be required by the time I'm in the market again. Good luck to the beta testers, because it is very much an unknown at this point...but at least it'll have plenty of grunt when it's working. :D
JoeFriday
Lansing, Michigan
3.0 Hurricane SO
Ferd did the Plasma arc lined cylinder sleeve bore, W low tension piston rings, on the 2018 5.0 cayote for it to be an oil pumper and use a Qt of oil every 2,000, there fix was to give you an upgraded dip stick W hash marks moved and told customers to add another Qt of motor oil when refilling.
You are telling my story here....I am the owner of a 2018 Ford F150 Lariat with the 5.0 Coyote engine..... Started noticing oil consumption at about 65k miles. I change my oil every 3500 - 4k miles until the issues began.
I had the Ford tsb that reprogrammed the PCM module and got the longer dipstick....seems to be a bit better....did an oil consumption test afterwards at the dealer and it used just under 1 qt of oil in 3k miles which was considered normal by Ford. I question that and think there is something about the plasma welded liners causing issues.
I am looking at the 2025 RAM.....I like everything about it but my common sense side says to back off because of this being a new engine.....and only being direct injection instead of dual direct and port injection like Ford and Toyota use (to eliminate the carbon buildup on the intake valves that direct injection only injectors cause).....
Haven't made up my mind yet...but leaning towards an F150 with 3.5 twin turbo. They are on their 3rd Gen of this engine...seemed to have worked the issues out of it...and unlike my 5.0.....the 3.5 has iron liners instead of the plasma welded ones.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Oil lines need to be larger and the radiator is like 4 gallons not 2 so anyone guess what temps a hot exhaust side of a turbocharger gets ?
Inter cooler is only for intake is “water to air” but is probably still anemic for the HO …
AND fuel consumption…
that’s the joke it’s the same as the V-8 but worse in the HO.
I think Stellatis is just using this as an afterthought
( Green Washing ) until hydrogen technology or electric battery generators are refined .
I’m all for a coal burning hydro electric power plant just to cut out the middleman for the charging stations and to the ridiculous gasoline prices.
Oh and where’s their a reliable source of 91 or better fuel that’s not 10% or better made with corn ? 80% of the HO’s will die of starvation and heat exhaustion within the first year of ownership
Ramfanski
I would not be afraid of the hurricane. I just bought a 22 hemi so unless I crash it, they will be old engines by the time I’m looking. The RamCharger has my attention now too.
Edward Hands
Youngsville, Louisiana.
5.7 E-Torque
Most people don’t even know exactly what they’re complaining about on the new engines.
There’s no exhaust manifolds on the hurricane engines.
So the turbo mounts directly to the head? It sure doesn't look like it from this picture:
Riccochet
Yeah, those turbos are bolted directly to the manifolds that cast in to the head.
The 3.6 Pentastar has the same style heads with manifolds cast in to them.
DanAR
Arkansas
So now instead of replacing a cracked manifold owners can replace a cracked head? :rolleyes:
I know, I know - just too good an opportunity to let pass.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I'd be lying if I said that wasn't the first thought that popped into my head too when I read about that. :D
Didn't know that about the Pentastar.
Edward Hands
5.7 E-Torque
I am optimistically hoping that they are as robust as the rest of the head and won't be prone to cracking as they were in the past.
But I'd like to pose a question:
Would you guys prefer an engine with the same power that you currently have but with better MPG or would you rather the same MPG and another 145 Horsepower and an additional 111 Ft/Lbs of torque?
