2006 5.7 Running on 3 cylinders
TLSF150
Ga
New guy here in need of serious help...
first off, the truck is a 2006 1500 5.7 Hemi with 125k miles.
I bought the 3 days ago it was running extremely rough, but I'm a pretty decent mechanic, at least I thought I was lol, so I offered the guy $1000 and after some negotiating (me not coming off $1000) he took it and i drove the truck home
the only codes that show up is a p0300 random misfire cylinders 1 2 3 and 4 all seem to be completely dead with misfire counts at 500 in the minute or so I was pulling live data, cylinder 5 is hit or miss with over 200 misfires 6 7 and 8 seem to be the only live cylinders but still had 1-5 misfires between them.
What I've done so far, replaced all 8 coil packs, all 16 plugs, no change, so I moved to fuel. pulled the injectors and really nasty brown fuel came out of the driver side rail, I went to pull a part and got 8 injectors out of an untouched 5.7 that was rear ended.. I also cut one of the injector pig tails so that I could make a diy injector cleaner... cleaned and tested all 8 injectors using a valve stem and battery they all worked perfectly. cleaned both rails out, installed injectors and again no change...
used my scanner to actuate the injectors with engine off and could hear all 8 activate...
pulled both valve covers and verified all valves were opening/closing, everything seems to be working and moving correctly...
so, I did a compression test all cylinders were 180-195.
fuel pressure is about 58 key on engine off, bounces between 60-65 very quickly while idling, it evens out at 65 at 1500 RPMs
as it sits now I've pulled the intake and again verified valves are opening and closing as they should, I'm going to replace the intake gaskets before re installing but I don't have high hopes of it fixing anything
I'm at a loss here, never have I encountered a truck that I couldn't diagnose or fix... there's no other codes, no O2 codes, no lean or rich, no cam or crank position sensor codes, nothing to go off except this p0300 that's kicking my butt
LoneWolf3574
'really nasty brown fuel came out of the driver side rail'
Have you drained and dropped the fuel tank? I only suggest dropping the tank to inspect it. It sounds to me like you may be trying to run stale fuel.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
Exactly what I was thinking. Clean out the fuel system, including the tank, and see how it runs on fresh gas.
OP, do you know how long the truck was sitting before you bought it?
T
TLSF150
Ga
update, I opened the tank up, wasnt really that bad but I went ahead and cleaned/flushed everything anyway..
put engine back together with new gaskets, and,......... still runs like ****...
LoneWolf3574
My previous suggestion was based on what you found in your fuel rail, start looking for vacuum leaks. Old, cracked lines and failed intake gaskets will lead to unmetered air entering the engine, in other words, a massive vacuum leak and an engine running like s**t.
T
TLSF150
Ga
Gave in and pulled the driver side head since no matter what I did cylinder 3 was always dead.. and finally found the culprit ‍♂️
