I recently replaced my Quad Halogen headlamps & taillights on my 2017 RAM Big Horn with new Morimoto XB LED housings and consistently receive a High Beam Headlight Out message. The problem occurs a few minutes after driving when the lights are turned off. Prior to the error being thrown, low &...
Hello all,
I have a 2016 Ram 1500 Express. It did not come with the brake controller. After watching many videos, getting Alfa and the obd dongle, I finished the installation I went in and changed the 4 or so items to change and let the vehicle go to sleep. From the different things I have...
I had ordered a new keyfob to replace my sentry key for my 2015 Express. I went into AlfaOBD to program the key. Was following a guide. I went and set my hub to accept RKE before pairing the key and it said RKE active but couldn’t find the FOBIK to pair when trying to pair it. Paired the FOBIK...
Replaced my low beam halogens with some Sealight LED's. They work for a while then blink a couple of times then go out. The dash then says that I have a headlight out. I have changed the settings using AlfaODB for LED Low Beam Lamps Present to yes. This change did not have any affect. Is...
Ram brothers and sisters…I’m at a loss tonight. I finally got the Alfa OBD for my 2014 3500. I did the usual, watched a YouTube video, and successfully programmed a new key fob and I was ecstatic. Figured I’d go ahead and adjust my tire size (37’s) so I’d actually know my speed. I must’ve been...
I've found tons of threads on turning on remote start with AlfaOBD, but non of them mentioned needing a module or controller for it to work, they just mention needing to wire the hood latch
Are there any other needed parts, or do you just have to turn it on and get a key fob with the remote...
Hey everyone, this site has been super helpful in the past so I'm hoping you guys can help decipher this one. AlfaOBD shows that some LF antennas are failing, which I assume is preventing the remote start from working. It looks like there are issues with the left door and interior rear antenna...
I want to program my fog lights to come on with BOTH high and low beams instead of just the low beams. That way I can easily control them with just the dash button. Can this programming be done with Alfa OBD?
2022 New body 1500
Many thanks!
Extra points if you can provide steps required if it...
16 ram1500 sport with air suspension
I made a mistake. I use alfaobd to write the body height (factory value). But the truck seems to have lost the leveling function. Now loading and unloading cargo can not automatically adjust the body height. And the left side of the body is an inch lower than...
Hi I have a 2012 RAM 1500 and was looking to buy the things to use AlfaODB to change some parameters on my BCM but I haven’t found anybody that has done it on a 09-12 I only see people with 13+ using it. Is 2012 compatible or am I just going to waste my money?
Thanks
Hi all! New to this forum. I recently purchased a 7”evic for my 2019 ram 1500 classic express. It came out of a 2018 sport. I purchase Alfaobd and obdlink Mx+ I cannot get my milage, engine hours or idol hours to change. I keep getting the same error message on the app. I have successfully...
Hey all... been digging through the forums and google for this... is how i came to some of the changes I've made, but I cannot get the hyperflash and codes to go away no matter what I've done so far.
2015 RAM 1500 + Morimoto XB LED assembly.
Symptoms: L/R Turn Signal Bulb Out Alert... they...
Hello everyone
So I installed aftermarket headlights (Alpha Rex) and like everyone else get the “Parking Light” code. I purchased the OBDLINK MX+, purchased an Android tablet and bought the AlfaOBD app. When I try to make a change AlfaOBD gives me the message “Procedure completed, but status...
So, I started making these step by step videos for us visual learners, like myself. I never intended to make my own thread on it.....However, @Lawsuit11 and a few others thought it would be a good idea to have all my tutorials in one spot, for ease of access for newbies.
I have a few...
