chrysler
  1. Bmags
    MDS Delete SOLVED
    Just wanted to share this, pulled the trigger and had my ECU tuned to delete the MDS from functioning. Super simple, mailed my PCM out and he mailed it back with no more MDS!!! The guy said if sending in my current PCM wasn't an option, that sourcing a used one could work too. Can't believe I...
  2. A
    Eco diesel engine blown
    I have a 2016 ram 1500 ecodiesel. 120,000 miles. About a month ago I was going around a curve not even touching the throttle and started hearing a pound clanking noise. I got out to check things over and oil was dumping out of the bottom of the engine. Idk if it jumped time or threw a rod or...
