Got a 2011 Dodge Ram 1500 4.7L - Been having a crank/no-start issue for awhile, it happens every morning after sitting overnight and tends to happen again after it's been sitting for a few hours after a drive.
What I've noticed so far, is if I go out and try to turn it over the first time in...
Hi. I have a 07 5.9 24v CR 2500
Sat for a bit, went to start, wouldn't start just cranked. Tried cranking again - heard a pop, then burnt wire smell coming from ignition area down there.
-Was throwing a code for crankshaft sensor so replaced that- Still no start just cranks
-was popping the ecm...
I bought my 2011 Ram 6.7 truck last October and it ran fine, except no cruise control. Within two weeks I put a new stereo and Viper alarm in it. In the next two weeks it started intermittently cranking but no start, but would sooner or later start. I took it back to the stereo/alarm people and...
My truck just shut down on me while driving on the highway and will not restart. I was doing about 60 and I had it in gear still(standard) just bogged. I got off the highway and ran the codes on it and said loss of injector communication. To this day it still will not restart. I checked fuel...
I have a 04 cummins
Main fuel pump went out
Had shop replace pump and go thru transmission
in less than 200 miles it has died/wouldnt start twice
Next day wouldn't start
Cranks but no start
Towed back to shop it starts
No codes they are unable to replicate problem
The lift pump was replaced...
I need some help. I can get it to idle off of B12 but will crank/no-start without it. Hooked a Dodge scan tool on it and it says PCM has no communication with other modules. Fuel pressure is good and noid light indicates injectors are firing. There is spark. Any suggestions?
