cruise control
  1. T
    Adaptive cruise control
    I have a 2024 power wagon and trying to fined out if adaptive cruise control and surround camera be added on at deal? I can not seem to get a answer from them
  2. T
    Can cruise control lowest speed limit be changed/reprogrammed below 20 mph?
    I would like to know how to change/reprogram the lowest speed of the cruise control (20 mph) to 10 mph. The vehicle is a 2020 RAM 2500, 6.4 Hemi. What kind of tool or programming device, is needed, and what are the procedures? The purpose of this is to more comfortably drive for many miles...
  3. C
    Cruise control won’t stay on
    I have a 96 Ram and recently started having problems with the cruise control. Everything was working fine and then the cruise started to turn off when I would touch the break. Not just disengage but it would actually turn off as if I had pushed the “off” button. When tried to turn it on it would...
  4. J
    Cruise Control and +/- Gear buttons not working, replaced brake switch
    HI My cruise control buttons and the +/- gear buttons are not working. Initial research suggested a replacement of the black-plastic brake light switch. I replaced it and the computer threw a "Check engine light" with P1C4E CODE. I cleared the code and the check engine light stayed off. The...
  5. H
    Cruise control randomly stopped working
    I have no idea why did this happen and what caused it. I used it every day to work and back and recently it doesn’t work anymore. any ideas on how to fix it? It is on a 2014 Ram 1500 SLT 5.7 Hemi. Thank you!
  6. D
    Unexplained Engine Problems (P0300, Unexplained Coolant Loss and Cruise Control Not Activating
    I have a 2005 dodge ram 1500 slt quad cab 4.7 Engine non-flex For the past 2 months, I have been having a p0300 misfire code (random intermitted misfire) and sometimes it will throw in a p0307 (cylinder 7 misfire) code. I have replaced my spark plugs in all my cylinders and replaced the...
  7. U
    Brake Transmission Shift Interlock affect clock spring?
    Hello all, This past summer, my truck was serviced for a recall in which they replaced the Brake transmission shift interlock and bracket-steering. The day I left the dealership, I heard a weird clicking noise whenever I turned the wheel that was not there before. I didn't think much of it. Six...
  8. RamItFaster
    Cruise Control Gear Shifting???
    So, while CC was on, I bumped the up or down arrow on the automatic gear shifter, I then saw on the dash that my "Gear" wasn't in Drive, it was in the Up and Down position next to Drive, and the Cruise Control Indicator had a 5 next to it, as in I was probably in 5th gear. I have gone through my...
  9. D
    ABS and 4X4 lights on, changed sensors and connectors
    Hi guys, I’m at my wits end. Abs and traction control is malfunctioning, can’t use cruise and 4x4 won’t work either. I changed abs sensors, connectors but still no luck. Here is something strange though... If I am towing a trailer; it all works fine. As soon as I unhook the trailer and drive...
  10. D
    Cruise control button
    So my cruise control on/off button is working sporadically. A couple times now I go to trim of cruise system and it won’t come on. Then suddenly, it decides to come on after pressing a bunch of times. Once it’s on, it works fine. Any thoughts?
  11. BSLugnut
    Brake Warning Light & Electronic Stability Control (ESC) Lights Stay On
    Hello, I have a 2012 1500 Laramie 4x4 Two days ago, I noticed that both the Brake Warning Light & Electronic Stability Control (ESC) Lights Stay On. In addition, the Cruise Control will not turn on. The brakes are soft and spongy while not moving. The brake fluid level is good and not...
  12. dgjackson40
    Service Electronic Brake Control etc
    1st post on this forum. My 2012 Ram 2500 5.7 liter hemi 4x4 began having issue with the integrated brake controller having a CF! flashing on the unit and now and again message to service electric brake control coming on. I then noticed electronic stability control indicator light on and that...
  13. K
    Advanced Safety Group - does it really function well?
    I'm about to order a 2020 Laramie. Please share your experience with the Advanced Safety Group family of products. Does it really work? (Does it work well?) Does it give false alarms? Does it "fight you" when you want to do something deliberately and safely but it thinks you're crashing and...
  14. G
    driving in cruise control with no trailer in the wind
    i am driving my truck with no trailer hooked up to the truck and i will be in cruise control and there will be side winds and it will knock me out from cruise control and i will get the service trailer brake controller and i will be locked out from using my cruise control.
  15. E
    Cruise Control / Searching for gears
    Does anyone know of a plug in tool similar to the pedal commander that will set the throttle at a certain position and leave it there for a time? I'm used to driving a stick without cruise control, so I learned what I always heard as 'fat boy cruise control' basically you set your foot on the...
  16. J
    2013 Cruise Control Switch Questions
    Hello, this is my first post and I've just now purchased a new to me 2013 Dodge Ram 1500 Crew Cab with the 5.7L Hemi. So far I'm loving this truck. Plenty of power and space. The previous owner babied it and it only has 50000 miles on it. I do have a problem though that I'm trying to figure...
  17. Drunken Hamster
    Wind Noise and Neutral RPM + No Cruise Control While Driving
    IDK if it's just me, the dent in my fender, a failing seal/window lifter, my loose rain guard window thingies or what, but my truck seems pretty wind-noisy lately.... Is there anything I can do to remedy this or improve the situation. I also have to constantly crack the drivers' window down and...
