Hi guys.
I am new to RAMs, just got a 2015 V6 and just realized it has a small leak where the rear drive shaft mates with the transfer case. Do you think this is caused by the rear output seal? is it an easy fix?
My rear drive shaft busted while driving down the road. The mechanic had a hard time finding a new one. Any recommendations on where I can find a new/good quality used rear drive shaft for this sucker?
I had lowered my truck sometime last year. did the flip kit on the rear and lowering springs in the front.
Not really sure if it was 4" or 6" drop on the rear. Anyways, the issue i had with the drop was that the drive shaft was rubbing on two different places. one of them is was on the hanger...
As the title states, I show you how I greased my front drive shaft fitting on my 2018 Ram 2500. The truck finally hit enough miles to require its first mandated service which included a tire rotation, topping of DEF, inspecting the suspension/front end, and lubricating the front drive shaft...
