exhaust manifold
  1. OutlawFMX
    4.7 Exhaust manifolds
    I have a 2011 Ram 1500 4.7L and I have to replace both exhaust manifolds, so I looked on Rock Auto and they only had the right side and not the left. I also called the Dodge dealership and was told the left side has been discontinued and only the right is available... does anyone have an idea...
  2. S
    2020 Ram 1500 Header/exhaust recommendations
    My truck: 2020 Ram 1500 Laramie Longhorn 5.7L V8 Etorque Motor. so I know it is common for the manifolds bolts to break or the manifold itself to crack. so knowing this I am looking for a non cast iron option that doesn't need need to be tuned when done. I have looked and found this header but...
  3. D
    New Heads & Manifolds
    I took my '01 Ram 2500 v8 to a local shop a few days ago to have the exhaust manifolds replaced. As expected, some of the manifold bolts broke off. Initially I was told that the shop could drill them out if they broke and that it would cost additional in labor. That was fine and I already...
  4. N
    Kooks Long Tube Headers
    Hey guys, new to the forum. Looking for some guidance before I buy a bunch of stuff. Looking to put 3” headers on my 5.7, with the high flow cat Y-Pipe. Primarily to fix the exhaust manifold issues. My question is, is there anything I need between the headers and Y-Pipe? Also are there any...
  5. B
    Changing bolt sizes on exhaust manifold.
    Hello. I recently picked up a 1986 1 ton Ram with 360 motor and a little dump bed. Last dodge I owned was a 1979 Power wagon way back in highschool. This 86 arrived with leaking exhaust manifolds. The fore and aft most bolts were broken from the get go on both sides. All 4 are flush or sub...
  6. J
    Exhaust Manifolds Debacle
    Love my 2010 Ram 1500 SLT Crew Cab 5.7L Hemi 4x4 now with 107K miles. I am the original owner. Did have the manifolds replaced by dealership 2 times while still under warranty BUT of course the tick and busted bolts came back. Decided I want to keep this truck as I have always given it TLC and...
  7. RampantJourneys
    Exhaust Manifolds | Warped
    I'm well-aware that the 5.7L HEMI has a fairly common issue surrounding the exhaust manifold bolts, causing the "HEMI tick". About 10 days ago, I noticed my truck had a tapping noise when cold-started. I assumed that this was the infamous HEMI tick and honestly didn't give it much thought. It...
  8. R
    do 6.4 exhaust manifolds work on 5.7 ram 1500?
    got set of 6.4 exhaust manifolds and not gunna use anymore and wanting to sell. having a hard time finding if it actually works on trucks or not. heard there is clearance issues with frame of truck? also heard jeep srt ones work? do others? i have set of a 300. any info is much appreciated! i...
  9. R
    Exhaust leak... again
    Got my exhaust leak fixed in May now in December it is leaking again not sure what to do. Should I call the dealer and see if they will back their work since I’m assuming it wasn’t done properly. 2011 ram 1500 5.7 with exhaust manifold leak please help
