2008 Dodge RAM 1500 TRX4 Quad Cab, V8 5.7L (Gen 3)
EDIT: This is now an intermittent issue, as it started working again the next day, just an FYI.
Just saw today that the tachometer stopped working. I did the whole self-diagnostic thing by holding down the trip reset and turning the key on and...
I have a 2005 5.7 hemi ram 1500. I’ve been testing lights on the clusters and noticed that when I run a C Code test it will cycle between A4, AA, AC, and AE codes every time I test. I can’t find an A4 code anywhere online, and the other ones are sone kind of ABS and PCM issues but I don’t have a...
I have a 2005 ram 1500 5.7 hemi with a manual floor shifter for 4wheel drive. Ever since I have had it the 4WD light has never come on on the dashboard even when engaged. The 4WD works perfectly in every mode. I ran a C Code test on the dashboard and every light lit up EXCEPT for the SERV 4WD...
As stated in the title, my newly installed EVIC 7in Instrument Cluster in my 2016 1500 Tradesman is displaying I have a brake light out.
I had read in the forums on here that it may be the third brake light but all is working in that department, there are no brake lights out
on my truck yet I...
I have a 2014 1500, single cab, 3.6 L V-6 that I just bought 2 months ago from the local Dodge dealer.
I noticed an intermittent issue with my instrument display cluster, mainly when I use cruise control.
When I tap my brake pedal to slow down , the display flashes back to display " Cruise...
I’ve read and re read the thread covering the proper wiring procedure with the pictures. I still can’t get any of my steering wheel buttons or horn to work. https://get.google.com/albumarchive/115651121177758204880/album/AF1QipNSLaFAq4zKa247XLaGUNYyujI3Lfg0C3OcBoIh?feat=directlink
2011 Ram 1500...
I'm having issues with my speedo cluster. The entire cluster works fine I just have 2 or 3 leds
inside the cluster that have burned out. Dodge wants to sell me a whole cluster ..which is overkill.
Anyone else have this issue ? I know bulbs need to be soldered but cant get any other info.
thanks
I've researched this a little online, and seen similar issues on other Dodge Rams and other brand (i.e. Ford) trucks: my Odometer light on my instrument cluster fades in/out, and has been getting progressively worse. Its to the point where the Odometer light on my cluster is out for a week or...
Curious if anyone had had the issue where the speedometer needle ticks back & forth and is stuck at zero? I have a 2015 Laramie with the premium cluster. The speedometer needle starts ticking once the instrument cluster receives power (opening doors, starting vehicle, etc.) The needle does...
I can’t find what this fault code is but I think it’s linked to the following symptoms:
When it starts and it's cold, the symptoms are:
• Windshield wipers constantly running at normal speed: not adjustable or stoppable.
• Steering wheel controls don't work.
• Seat heaters don't work.
I have seen many post about this and trying to find out what happened.
Two weeks ago the truck wouldn't start and so we jumped it and went and purchased a new battery.
We took our truck to the dealer last week because it wouldn't start. We had to jump the (new) battery to drive it there. On...
Hi everyone, I've had my truck for 3 weeks and never noticed this before. There is a small crack in the bottom left of the Inst Cluster, I'm hoping it does not get bigger. Can this piece be replaced separately? Please don't tell me its part of the cluster itself. Thanks.
I have pounded the interwebs trying to find out where this relay is located and found a bunch of places selling replacements but no diagrams or locations. If it's in either the engine compartment or interior fuse/relay box, it isn't labeled as such. Can anyone, please, for the love of my sanity...
Truck starts perfect in the morning, Starts perfect after work (sits 8hrs). After
work (or even just regular trips from home) if i go anywhere IE: grocery store / home depot and come back to start my truck it
intermittently wont fire up. Everything works except the battery gauge is to
the far...
Hey there fellow 3rd Gen owners, I have a bit of a peculiar issue. I just installed a set of LEDs in my instrument cluster. During the process of swapping bulbs, one fell between the gauges and the PCB for the cluster. So, I had to pull it apart - which required taking the needles off. Some...
2011 Ram 1500 Quad Cab Big Horn
The other day I went out to goto work and the electronic display (EVIC) was not working, it was just blank, but the analog gauges worked fine.
I hooked up a OBDII and found no codes. I decided to disconnect the negative battery terminal and possible reset...
