Hi all, I just recently purchase a 2023 Ram 1500 limited with 4k miles. It seems to drive amazing BUT when I make a hard left turn, the steering wheel/column makes a subtle noise when the wheel turns itself back to being straight. It sounds almost like an electrical buzzing or gears. Could it be...
First post. One Owner (Me) 2003 Dodge Ram, 4wd, Auto, Quad Cab, SLT, Cummins
In my attempts to troubleshoot ignition problems, I have discovered this white connector will not lock and stay. What are my options? My local shop was able to identify this as the C1 clockspring connector, and the tech...
When I pull the headlight switch, the running lights and brake lights come on but the headlights do not. When I pull the multifunction switch, the brights come on but it won't "click" and stay in place. I have to hold the multifunctional lever toward the steering wheel. I am guessing my dimmer...
I bought a 1983 Dodge w150 with an aftermarket steering wheel that I don’t like and want to replace. I bought two different OEM steering wheels on eBay, but the spline count appears to be different than whats on my steering column. Online research shows there are two different styles of steering...
Noticed a rattling sound/Buzzing in my 2016 rebel that sounds like it is coming from steering column or under the instrument cluster on left side. It only occurs at higher speeds (55 mph and up) and doesn't always rattle. Needless to say I cannot locate it and it drives me batty when it happens...
I am looking for the bracket that mounts on the steering column for securing the gearshift indicator cable. For the first image, I believe I need the black bracket on the left side of the cable with the thumb screw. The second picture is from the actual truck. Does anyone happen to have...
Vehicle: 2008 Dodge Ram 3500 Megacab
The circled part was attached to the column gear selector upon replacing and I broke the tab off of it. It looks to be a push lock of some sort but I have yet to find an actual name or part number for it.
Currently, I only see this part on ebay bundled in...
Ok I just bought a 2003 dodge ram 1500 slt 4.7l V8 magnum just under 120,000 miles on it. My issue is after I did the paperwork an got the keys I drove 20-30 mins to my insurance office an when I shut her off my blower stayed on it wasn't blowing cold nor hot air just like it was sucking air...
