stumble at idle
  1. J
    2015 3.6L- replaced oil cooler, now has stumble issue when shift into gear.
    I had an oil leak that I diagnosed as a leaking oil cooler on my 2015 Ram 1500 3.6L engine with approx 160K miles. Pretty common issue from what I have read. I replaced the oil cooler assembly this past weekend and leak was gone. I used a bunch of shop rags to soak up as much oil as possible...
