torque converter
  1. 1
    46re torque converter locking and unlocking. Also no overdrive?
    Well Ive got a 1998 Ram 1500 5.2 2wd 46RE. For the past month, the truck has had a weird shifting issue. On point and at exactly every time, when the truck reaches the 3-4 upshift mark, the rpms jump about 400 or so rpm for a second or 2. If im going uphill, that will sometimes stay like that...
  2. E
    Transmission problems
    Hi, I have a 2005 Ram 2500 2WD with a Cummins and 136k miles. I noticed that after driving at highway speeds for more than ten minutes my transmission starts acting up. After exiting the freeway and coming to a stop, acceleration from standstill is slow and difficult and requires excessive RPM...
  3. Bear_Gibson
    99 Ram 5.9 pretends to have turbo lag
    So as many of you may have noticed, my ole' dodge has been acting up lately. It all started a few weeks ago when I was heading to work. It drove perfect when I left, and then when making a left off the highway it was like the engine suddenly shrunk. It has no power on take off, after getting...
  4. H
    2004 5.9 Cummins trying to accelerate against break pedal.
    Hi guys, I have a 2004 dodge ram 2500 5.9 that Seems to have no issues while in neutral, but when in Drive or Reverse, the truck accelerates to around 2-5mph. When I apply the brake pedal, the truck continues to try to accelerate at a low level against the brake pedal and sounds like it is...
  5. B
    06 Ram 1500 Transmission Issues - Advice Please
    Hi And Thanks ahead of time for your advice I have a 2006 Ram 1500 SLT Quad Cab 4x4 5.7L HEMI A/T with about 145K, I bought this truck as trade into my old dealer about 5-6 years ago with 100K on it. Since I've owned it I've replaced the bedsides, NHOU undercoated every year, replaced...
  6. Black_Crystal_Ram
    2014 Transmission Upgrades
    So I've been looking around and reading and have come to the conclusion that I don't have the bank for any major HP gains on my truck. With that being said, more HP was a means to an end, the goal was better acceleration. I found another post suggesting new gears in the rear axle (4.56), torque...
  7. M
    Torque Converter issue?
    Hello everyone. I'm new to the forums and hope this is posted in the right section. I'm having some very troubling problems with my Dodge. It is a 2002.5 (3rd gen) ram 1500 SLT 4x4 with the 5.9l Magnum and a 46re auto. I've been driving the truck for over a year with no issues, however it...
  8. Kustomblack1
    Daily driving 6 speed with cam and converter
    10 to 12 minutes of my trucks driving characteristics during normal driving conditions with a 3k converter and HPT cam shaft.
  9. G
    Torque converter issues
    Hey what’s up folks, new to the forum and dodge. I bought a 06 5.9 a few months ago to haul my camper with. Recently it started to make a squealing noise when you’d let off the throttle, it would go away once you cracked the throttle, I had thought just quickly belt squeak or turbo whine of some...
  10. M
    Torque Shudder
    Anyone have a torque converter shudder issue? If so, were you able to fix it without replacing the converter? Thx
  11. Snowmanak406
    torque converter 46RE
    I am in the midst of rebuilding my transmission and running into an area where i am brand new to the science of; torque converters. I have swapped and removed transmissions before(usually on chevy's nothing against chevy but they are cheaper so people are more swap happy) but never was my own...
