upper control arm
  1. O
    Upper Control Arms
    Quick question. Would zone's upper control arms work/fit if im running a BDS 6 inch lift? I just ordered the BDS upper control arms for the 4-6 inch lift but I am not sure if they were worth the almost $800.
  2. C
    Bad ball joint
    I have 2014 Laramie 4x4 and the other day my upper ball joint popped out. Today I bought a new uca with a pressed ball joint and after installing the ball joint seemed to raise slightly from the control arm. Should I be concerned or is this normal or should I be concerned? I bought the uca from...
  3. Ulises1775
    Bilstein 6112 with Zone UCAs
    2017 Ram 1500 Laramie, Crew Cab 4×4, 6'4" bed. Had Bilstein 6112s installed at 2.8" along with Zone UCAs today. Afterwards took it in to Les Schwab Tire Center for an alignment. I go to pick up my truck once they're done; I ask them how the truck did and they tell me everything was good. Drive...
  4. 14Fiveseven
    Upper control arm Angles
    I lifted my truck in late January this year. Got the maxtrax 7inch lift (2wd). I had heard of the issues with the UCA failures and I asked but everyone said not to worry. Im looking at them now and I just want to make sure this looks ok?** Images attached** I would greatly appreciate any...
  5. WamBam
    Possible ball joint issue
    I have a 2012 1500 with a 4inch procomp spacer kit with bils up front set to to 1.2 to level out the truck. my steering wanders left and right when I drive and im thinking that it could be blown ball joints. does anyone have any insight as to what it could be?? ill post some pictures of the...
  6. J
    2 inch leveling kit
    I just installed a 2in motofab spacer leveling kit. Just wondering how bad I will be affected with the geometry. How important is it that I should change upper control arms or will I be okay with stock uca. I don't do any off-roading.
