2wd lift kit
KyleMatthews
Magnum 5.2
I have a 1999 dodge ram 1500 2wd with the 5.2 magnum engine. Does anyone know where I could find a lift kit for it? Not a leveling kit, but a lift.
Azteklb
Long Beach
Ive been looking high and low and I can't find anything either. Been looking and calling everywhere!
Ive found kits for regular cab but nothing for my Extended cab
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
They should be the same if it's a suspension lift
Moparfanatic21
Apparently they don't fit but idk.
I'll check it out
Thx
The only think that is different is the frame length. The suspension is identical
97magnum
5.2 Magnum
I lifted my 2wd recently. using 2 inch coil spacers up front, you extremely limit your suspension down travel unless you go with aftermarket control arms like the Doestch or Fabtech. You will also run into a problem where the ball upper ball joints tapered end will start to hit the bump stop mount, requiring you to cut that piece off. Both Doestch and Fabtech make control arms, springs and spindles for the application. Good luck!
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
They have lift spindles, coil spacers, and body lifts. Those are all your best bet, depending on desired amount of lift.
