360 to 4BT
tonyace121
Has anyone swapped out a 360 for a 4BT Cummins?
TheMaddog
DFW
I thought about doing it. But then I got a HEMI.
But is love to see it go down. And the mpg's.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I personally dont think a 4bt is a good fit in a half ton truck. Your better off building a 408 stroker IMO.
4bt weigh 150lbs more then your current 360 and have about the same power
Your tired 360 is rated at 175hp and 260 lb-ft of torque. 4bt are rated at 105hp and 265 lb-ft.
It is easy to turn them up a bit but anything more then 170hp and your either spending big money or blowing it up.
350 hp and 400 lb-ft on pump gas seems like a much better option to me.
If you really want to do a 4bt swap, get a cj5 or cj7
T
tonyace121
It's actually a 1 ton dually. Auto trans. High ratio rear end....not sure about the rear end ratio but I want better MPG's and Diesel for sure. It took me awhile to get the Hemi out of my brainpan...
Stroked
Beloit, Kansas
Does your trans have overdrive or is it just a 3-speed. Overdrive is almost mandatory with a diesel.
I think it'd be a cool swap, just don't expect it to be like a 6bt. Probably more comparable to the old gm 6.2 diesel as far as acceleration.
WhiteExpress
Midland, TX
I don't see anything here where he is expecting massive HP...
I think a 4BT swap, running on B100 would be awesome-ness!
Funny, I was thinking about this just the other day.
I will admit, a crew cab dually might be a bit much for the little motor.
Maybe convert it to SRW and make it a short box while you're at it. SWEET!
Hollabakzach23
Lafayette, IN
I would love to throw a 4bt in mine!! Almost snagged one when I had my ford but the guy sold it out from under me :/
TheMaddog
DFW
Hate it when that happens. But you'll find another one.
USMC1188
SW Ohio
None
Truckless...
4BT swaps are awesome! I would be tempted more for a 12V swap with a truck of your size though... I guess it all depends on what you are really looking to get out of your truck on what your best route would be.
ramhunter9
P-Star Jeep Wrangler
4BT swaps are good for the jeepers IMO
T
tonyace121
I'm just want to turn it into a local hauler....its a flat bed....2-doors...no overdrive. I could get an overdrive tranny and cut the drive shaft down if I have to. Not looking for speed or a lot of HP.
Stangshcky12
Oshkosh, WI
5.9 Cummins
itll be like going from one dog to another and mpg's wont even be that great
T
tonyace121
Just found and od tranny behind an old dakota engine in the garage...could use that and change gears in rear end. Would that be better?
