ABS and Brake Light on
huntw19xx
Washington
5.9 Magnum
Alrighty. I just bought a 98 1500, 5.9 4x4. Runs and drives. However, it has no front axle shafts, and 4 wheel ABS. I noticed on hills its severely under powered, and when going ~40 mph it will shake pretty roughly. The spindles with the ABS rings are in the hubs still. Checked all sensors, and wires, they are good (unless I'm an idiot and missed something). Doesn't shift well, and the tachometer and speedo work intermittently. Is all this just from the axle shafts not being in??
cbassrex
