- Apr 3, 2013
- 602
- 98
- 2013
- 5.7L
DIY: 2013-2014 Ram add OEM Backup Camera
DIY: Add a Backup Camera to the 2013-2014 Ram:
Downloadable Instructions
This is been tried and tested on the following years:
This is been tried and tested on the following models:
This is been tried and tested on the following radios:
Parts list required, for all models:
Parts required, for trucks without a power locking tailgate:
Before reading my steps, be sure to read the attached pdf.
Step 1: Remove tailgate cover
Step 2: Remove the tailgate handle
Step 3: Configure new Handle.
Step 4: Attach the wiring harness to the tailgate handle
Step 5: Install tailgate harness, if not already equipped.
Step 6: Re-install tailgate handle assembly.
Step 7: Remove the tailgate connector from under the bed of your truck and connect the custom chassis harness.
Wire the connector:
Using a small slot screw driver, pop the white face off of the connector.
Remove the white plugs from pins 1 through 6.
Insert the wires from the new harness into the slots, using the diagram below.
Re-insert the white plate.
Step 8: Run the wire to the chassis connector pin.
Follow the factory wiring and zip tie frequently.
Ground the ring terminal at the factory harness ground point, behind the left rear wheel.
Continue running the wire towards the chassis connector, just behind the left front wheel well.
Step 9: Wire the Chassis connector.
Wrap the wire at the connector with the notched plug and insert the connector into the slot for pin 26.
Insert the remaining pins according to the diagram below.
Step 10: Remove the Radio
- 2013:Tested and works
- 2014: Tested and Works
- Longhorn: Untested
- Laramie: Untested
- Sport: Tested and works
- Outdoorsman: Tested and works by blikike
- Bighorn: Tested and Works
- SLT: Tested and Works
- HFE: Untested
- Express: Tested and Works, 2013 Express requires slightly different harness
- Tradesman: Tested and Works, 2013 Tradesman requires slightly different harness
- 8.4AN (RA4): Tested and works
- 8.4A (RA3): Tested and works by blikike
- 5.0 (RA2): Tested and works by castires.
- Camera: 56038978AE
- Tailgate Handle: 68197873AA
- Camera/Lock Harness: 68189124AB
- Custom Wire Harness to install camera...click for link
- Tailgate harness: 68096415AC
- Requires the addition of power locking tailgate connector, with custom harness. This should enable power locking tailgate, assuming you install the solenoid.
Using a T-30 torx bit, remove the 8 torx bolts securing the tailgate panel.
Disconnect the actuator rods.
Disconnect the tailgate locking harness from the tailgate harness.
Using an 8mm socket, remove the two nuts holding the assembly in place.
Using an 8mm ratchet remove the locking mechanism from the old tailgate handle.
Using an 8mm ratchet install the locking mechanism onto the new tailgate handle.
Using a ratchet sized to the additional screws you bought (mine were 7mm), attach the camera to the new tailgate handle.
Here is a picture of the original wiring harness next to the new wiring harness. the old one is on the top. Just attach the new harness to your camera and locking mechanism.
I did not complete this step, and as I mentioned earlier, I am not sure if the body harness exists on trucks without power locking tailgates.
Here is a picture of the tailgate harness.
Attach the camera/lock wiring harness to the tailgate wiring harness.
Re-assemble everything back in reverse order.
Re-install the tailgate cover.
Wire the connector:
There should be 5 pins that need to be wired.
The first (white wire) is larger than the rest. This wire does not have a weather seal. Remove the plug from pin 26 (blue plug) and cut a notch to fit the wire. Also pull the other four yellow plugs
Remove the plugs:
Remove the white plate:
Remove the plugs:
How to take out a radio out of a 2012 Dodge Ram with a console. - YouTube
*This is not my video
