2014 RAM 1500 ABS Module seals
Yogi Beer
I have a 2014 Ram 1500 5.7 Tradesman and am getting a C2200-49 code so I am sending the ABS Control Module (removed from the motor part) off to be repaired because OEM through RAM here is over $1200. I can get it rebuilt for a little over $400. I want to replace the 12 little ring seals that are not furnished with a rebuild. Does anyone know where these can be found? RAM dealer here says they can’t be ordered and only come with a new complete unit. I see photos of them in separate plastic packages that come with new modules but can’t find them. Thanks
JD2015
Jacksonville Fl
I have the same issue with my 2015?
Where did you get it rebuilt?
How long did it take?
Did it fix the issue?
Y
Yogi Beer
Hi, I was going to send it off but couldn’t get in touch with them so I bought one on eBay and installed it. I now am trying to find a way to reprogram it. I just saw a place tonight on the internet called Module Master in Idaho that rebuilds them. Good luck. Damn RAM should have recalled these
FinestTitan70
