AC Compressor Clutch blowing fuses 2018 Big Horn 1500
Raddodge
Graniteville, South Carolina
My compressor clutch stopped working, and I found a broken wire in the clutch wire connector. It was broken so close to the connector, I had to remove the connector and hard wire the clutch. It went back to working for a while, and then it started blowing the 10 amp AC Clutch fuse. I hated to do it, but I jumped 12 volts directly to the clutch to make sure it still works, and everything runs fine.
I was told that the plug has a diode in it that it needed, (although it ran for a while without it), so I tried jumping in a plug from a donor Chrysler from the junkyard. It still blows the fuse everytime I energize the AC.
Does anyone have any ideas on what I can do or check?
Thank, Bob
McBroom
Denison Tx
Hemi 6.4L
Sounds like a direct short somewhere. I'd start by checking all the positive wires to the switch. Or if its u Derek warranty then back to the dealer it goes.
Blue Mule
HEMI-FI
Active Duty Air Force ( B-2 Hydraulics)
Warrensburg Mo.
I self induced the same issue, pretty sure the TIPM is done, I've checked everything else.
FinestTitan70
