RebelDad
alabama
Ordered a 18" magnaflow. Was gonna go with black widow but really just want to quiten it down a good bit.
Currently have the bolt in Carven Competition exhaust gonna sell.
CanuckRam1313
Ontario Canada
2023 Warlock SLT
I had a 22" Magnaflow and switched it to a 14" Magnaflow.
It sounds sweet!
And from a standstill at WOT, it barks nicely on the 1-2 and 2-3 shifts.
The 3-4 & 4-5 shifts are super nice as well.
Warlock2024
Northern VA
V6
So far this week, all I have done is drive to work. Plan on driving back home this afternoon! :) However, over this past weekend, I did drive to a buddies house and we ran speaker wire on his pontoon boat and got the speakers hooked up! Probably had a couple too many beers also.
Last week I plasti dipped the RAM on the grill and my antenna.
RamDiver
Marlborough, Ontario, Canada
:cool:
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Yes..pics,
and... how did you mask it off and was it their glossy or standard spray?
I'm wanting a dull/matt finish and not glossy... that would stand out too much on the front grill.
I, too want to do this with the RAM on the front grill as my whole theme is black & copper..
I'll also do the tiny chrome antenna base as well... no chrome/silver on my truck at all...lol
Now, I just need to figure out how to blacken the key hole on the drivers door handle so I don't gunk it up inside and disable it.
RebelDad
alabama
It sounds sweet!
I almost thought about the 14" but I guess I'm getting old and I'm on my phone alot in my truck.
Instead of the magnaflow I'm almost thinking about sending it back and getting the Blackwidow 300
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Stick with the Magnaflow is my $0.02...
Great tone and subtle...makes the HEMI sound great.
At WOT it wakes up and let others know there's a HEMI under the hood ;)
Warlock2024
Northern VA
V6
@CanuckRam1313 Ram, for the grill, I popped the hood, removed the plastic cover that has 6 plastic clips on it, placed a piece of cardboard between the grill and radiator, taped off around the letters and applied 3 coats (regular spray) going light to heavy. For the antenna, I hung it in the garage with cardboard on the floor, sprayed (same 3 steps).
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Thanks, Brother!
NETim
Nebraska
5.7L
I attempted to replace the cab vents BUT after I went to the trouble of pulling out the rear driver's side seat, I discovered that the new type vents were already installed! :)
I hadn't been having any leaks in the cab that I know of. I just like to be proactive. The truck sits in the garage out of the weather though.
I wondered why the seat frame hold down bolts were so easy to remove. :)
Wulf
United States
Did the same thing I have been doing for the last almost 2 months. Waiting for Blue to get back from the Doctors, broken transmission. Once I get her back, I have plans to get a bigger gas tank put in, and probably before that, custom exhaust work to make her sound mean.
At some point, also going to look into getting aftermarket Warlock badging done, in Blue Streak tho, so it looks factory-ish.
Bandit517
That Trials Guy
Wauseon, OH
Got the magnaflow put on. SOOO much better than the carven progressive bolt on. Gonna throw it up for sale on facebook
I went from a Carven Progressive to a Flowmaster FlowFX for the same "Getting old" reason. After long tubes and offroad Y pipe the Carven was WAY too loud for my liking. I have thought about actually tracking down another stock muffler and just adding an electric cutout before it. That way the truck can be nice and quiet when it needs to be, then when I want to let the motor roar, open the cutout. But that requires me to undo all the muffler/resonator work I did to make it sound as good as it does. So I probably won't ever get around to it.
hunterdan
SE PA
2019 classic
I keep thinking of doing something different as well. I went from the progressive to a black widow 10". The black widow sounded amazing, but the drone was horrible. I swapped that for the magnaflow drop in. I miss the sound of the carven and black widow, the drone with the magnaflow isn't near as bad, it's totally bearable and didn't have any issues after driving from PA to key west and back. But I miss the rumble of the other mufflers. Stock with a cutout seems like a reasonable option, but I'd rather not mess with a cutout of I don't need to. The mbrp drop in seems reasonable but have no idea how the drone would be.
Highway
Ky
How loud is the “18 ?
Highway
Ky
I tackled the front end, new cv axles , intermediate shafts on both sides , upper control arms and pressed in new ball joints. Just ordered new inner and outer tie rods from rock auto, about 50% worn so i figured change them while i did everything else.
