tbowers391
Ok y’all, I have read up on the multiple threads here about using AlfaOBD to program fobs.
I have the keyless touch and go or whatever push button “highline” fob on my 2013 ram laramie 5.7.
A year or two ago, my fob quit working. Changed battery and still nothing. Learned to do the touch the push button with fob to start the truck, and just basically never locked my doors after that(have to be pretty smart to start it and steal it)
Anyway, I stumbled my way here and have been trying to program my new highline fob. Everything seems kosher going through the Alfa obd process except when I put in pin and finally click “start” on program ignition Fobiks highline system it just starts the process and after clicking OK and then pressing unlock button once, it never finishes. I’ve tried letting it sit all night programming and tried in general multiple times and never get anything.
Could it be because my current fob is dead and it can’t copy or something? Or is it all coming from the RFhub in the truck anyway?
I also ran “check FOBIK product type” option in OBD and it just says No FOB.
“Locate Learned Keys” obviously gets me nothing as well.
Here’s a link to the process I am doing from a diff forum. It was just the quickest I had on hand right now but I think y’all know the process.
Followed procedure
Attached a pic of “no Fob” detected, and also a fault code with KIN/IGNM if that has anything to do with it
Followed procedure
