David Vandercook
Well, I finally got my 86 power ram to run today so I took it for a drive. It ran pretty well, but it felt like it was working really hard on the hills and wouldn't get above 15 up the steep hills. On flat ground it would go 40 if I completely floored the pedal. It shifted from first to second but not third. I came home and the rear drum brakes were smoking. The brakes seemed to work fine downhill but it might have just been the front brakes. Would locked brakes cause it to go slowly and not shift into 3rd?
Thanks, David
Thanks, David
