rough idle
  1. mill
    Rough idle, Slight Misfire with no codes
    Hey y’all! I’ve got a 2008 ram 1500 with a 3.7L. I had noticed that he was idling rough and I was feeling a slight miss but I didn’t have any engine codes and the misfire monitor was ready. I was able to hook up a scanner and see that cylinder 4 was missing about 18 times per 200 revolutions. I...
  2. R
    2009 5.7 rough idle until warm. Any ideas?
    Hello, 2009 5.7 hemi with almost 200,000KM on it. The truck started idling rough or driving really bad at low RPM. It vibrates badly. At high RPM it goes away and when it warms up it also goes away. The codes thrown were; P0300 - Multiple Cylinder Misfire P2017 - Intake Manifold Runner...
  3. S
    Multiple Misfire 2009 Ram 1500 5.7 - Need Help
    Hi guys, new to posts and ram 5.7 truck in General. But basically my issue is the multiple misfire code I am getting, and it does not show me which cylinder is actually misfiring. I had got the truck for a fair price due to misfire on cylinder #5 and did all the basic tests and ended up needing...
  4. M
    2017 5.7 VERY Rough Idle…But only for a minute
    Kind of a weird one here. I did search around on the forum to make sure I wasn’t double posting, but couldn’t find anything quite like what I experienced today. A little background: 2017 Ram 1500 Sport 5.7 Hemi ~85,000 well maintained miles Have always run the “recommended” 5w-20 changed at 7k...
  5. P
    Almost growling at idle
    I have a 2016 2500 6.4l hemi. When driving and I come to a stop sign or light there is an almost growling noise coming from what sounds like inside or under the dash. I can fell it slightly in my brake pedal, (keep in mind, when I’m already stopped, not stopping) almost goes away if I turn the...
  6. RAM208
    Rough start-up
    14 Ram 1500 with the Hemi, all stock besides Cold Air Intake and exhaust. For the past few days upon start up the truck idles rough for a few seconds before "coming alive" like normal. It almost sounds like the truck is cammed when it first starts. No check engine lights, nothing. It last for a...
  7. 9
    Truck Running rough
    Hi all, I’ve got a 99 ram 1500 5 speed 4wd that is running like crap. Idles rough, and will barely pull itself out of the drive way. The engine has new: cap,rotor,plugs, wires, coil, o2 sensors,injectors, cam sensor and crank sensor. I’ve tested and tried everything I know to test and replace...
  8. B
    Any idea on what to do next?
    Hey all, I have a 1989 W150 with the 5.2. Sorry for the long post but here’s the whole story: Bought the truck from a “dealer”, ran fine for a couple months (driving into town a couple times, that’s all). It didn’t have much power so I figured I’d change the plugs, wires, and do an oil change...
  9. S
    2016 RAM 1500 Randomly loose throttle and force to shut off
    Ok, so I have a 2016 Ram Express 1500 Single Cab. 5.7l with Edelbrock E-Force Supercharger and Long Tube headers (catless straight pipe). The past month I have been having a problem where I would slow to a stop and the truck would suddenly give me a message to “Shift to P to start then select...
  10. MrFixIt
    Help, 03 5.7L hemi Lost idle
    Can anyone explain why I lost idle after a tune up in an 03 5.7l hemi? I replaced fuel pump/regulator, sparkplugs, airbox sensor, Throttle Body, air filter, and a couple other things. The engine sounds fine when idle it held at 800RMP or higher, but has a rough idle at 550 rpm and dies shortly...
  11. rowemesp
    2017 1500, 5.7L, 22,000 miles P0307, P0300, check engine light on
    In recent weeks I noticed that the idle was a little rough at times, but the truck seemed to drive OK and engine roughness wasn't noticed while driving it and at that point it showed no codes stored in the computer. I put fuel system cleaner in one tank of fuel with no improvement...
  12. H
    Rough idle in park?? 4th generation Ram 1500 Classic
    Hello, I have a 4th Generation Ram 1500 Classic 5.7 HEMI that I’ve noticed has started to idle rough and stumble around in park, especially after cold start, it’s a bit less noticeable after warmup. If I rev the engine it goes away initially but if I hold it around 1,000 to 1,500 RPMs it starts...
  13. J
    Red lighting bolt - Truck stalled and died
    Long story short I was driving and got the flashing ETC. Truck went to idle fell on its faced knocked a bunch and shut off. AT this point no CEL. Towed home tried to start and it started but super low idle and sounded like timing was way off. A lot of knocking and pinging. This time I got a...
  14. E
    2002 4.7 Rough Idle
    Ok guys and gals. I have been searching for weeks now for an answer to my little problem. Last year the truck died on the way to church, was able to get it restarted enough to limp home. Long story short this is what has been done: Full head overhaul on both heads, everything is new Replaced 4...
  15. Cowboy Brick
    Rough Idle, Misfires, Rough acceleration, any help?
    I got a 2012 5.7 Hemi. Got my truck back from the shop and it's been misfiring since. They replaced a leak in the manifolds that was causing the tick and the tick is gone now. They also replaced the o2 wiring harness from the injectors all the way down to the o2 sensors and replaced both...
  16. I
    rough idle 124000 1500 5.7
    i have 2012 dodge ram 1500 big horn 5.7 hemi. brought used and not under warranty since i brought bit of rough idle it performs well replaced spark plugs no codes or any problems and clean throttle body. but still feel it what else could cause I'm doing a full fluid flush through out truck only...
  17. D
    95 ram 318 rough
    1995 318 idles semi ok cold but spits an sputters when warm. Won't get past 15mph after a 2 min drive. New plugs, wires, map, tps, aits, crank position sensor, air filter, o2. No vacuum leaks that I know of. Any advice would help.
  18. W
    Rough and Inconsistent Idle, frequent stalling and bogging down under acceleration
    I have a 2005 Dodge Ram 1500 Hemi that I have been trying to fix for almost two years now. My brother ran it to empty one too many times and clogged up Injectors and the truck wouldn't start properly again. Had my mechanic take it apart to find the cause and found that a valve had broken off...
  19. USMC-ORDO
    Troubleshooting a 5.7 engine issue
    Hello everyone, I have exhausted my "know how" and have decided to see if anyone can assist here. I have a 2013 RAM 1500 5.7 with 106,000 Miles. I took off on a 800 mile road trip recently and about half way I felt my truck start to idle rough (very mild at first) it was only doing it during a...
  20. M
    Please help 05 dodge ram 5.7 hemi rough idle
    My truck recently started idleing really rough I'll crank it and the revs will go up and down between 4-9 hundred rpm and lights will flicker.I'll give it some gas and it'll stop idleing rough until I let off then usually it will die and start smelling like gas. I've replace the egr valve and...
  21. J
    04 1500 2wd 5.7 hemi Sputter Idle
    This will be a long one. I have been fighting my truck for going on 2 months now. Problem started suddenly, Was driving, no issues, pulled into a parking space, and the truck stalled. When it stalled the steering wheel ******. Check Power Steering (PS) fluid, fluid was very low/non-existant. Put...
  22. T
    Multiple Random Misfire fixed, but not
    I have a 2002 dodge ram 1500 SLT 5.9L with roughly 153,000 miles. A couple weeks ago went to start my truck and it wouldn't start, but would turnover. Done some digging and spark plugs were in bad shape so I got NGK spark plugs and put in it and it started right up. I drove it that evening and...
FinestTitan70
