- Joined
- Aug 14, 2018
- Posts
- 4,202
- Reaction score
- 3,891
- Location
- ASTON,PA
- Ram Year
- 2012
- Engine
- AK Trucks Tuned 5.7
Ok so given you want to spend the extra money on the Bilstein 6112’s tells me that you have ride quality in mind. I would do a Zone 6” lift with 3” rear coils. @Nick@GotExhaust can set you up with the parts so I’m listing them for reference and not confusion.Yeah that’s pretty much what I’d like there
Hear me out. Zone 6” lift with Bilstein 6112’s set to 0 with no preload spacer. Will net you 5” of lift in the front. Bringing up the rear 3” should leave you at a perfect 1” rake making you appear dead level. If you ask Nick for the quick_shifter package he will include the extended braided brake lines. You will not need the Zone UCA’s right away to save some coin but I would put them on the “want” list. Your stance will look like this with factory wheels. And your Ride will be much nicer than the readylift kit. This is @RJL1 truck he has been stance pictures
Keep in mind this picture is fresh off the lift so it’s up about 1 1/2” the suspension settles on all vehicles when then come down from a lift
