replaced air ride with 6" lift. Still getting service Air ride message.
AML Homes Michael
Decatur TX
Eco Diesel
I have a 2016 ecodiesel 4wd. Just replaced air suspension with 6" lift. Installer fixed the sensor issue. Its been a month now and the "service air suspension" code has come back on. Can use auto start or anything because of it. How do I disable the air ride system completely?
DILLIGAF
Canada
Turn it off in Alpha ODB
A
AML Homes Michael
Decatur TX
Eco Diesel
How do you do that? Its on euro mode in the settings and the fuse to that system has been pulled.
A
AML Homes Michael
Decatur TX
Eco Diesel
They dont have it for Iphone. Its not in my app store and the link you sent says windows and android. Any suggestions where to get it? Can I go to my local autozone etc.?
A
AML Homes Michael
Decatur TX
Eco Diesel
Here is mine, Love the look. Just wish the air ride stuff was gone so the autostart would work.
Nick@GotExhaust
Preferred Vendor
SC
I dont even use it, so I am not sure. I just know thats what the majority of people use. Hopefully someone else can help out. Do you not have a windows PC to use?
Ramulus
TX
Eco
FYI you need to put the fuse for the ASCM back in, then talk to the ASCM to disable it.
Disable with AlfaOBD and THEN pull the fuse. Post #5 here has some more info:
https://www.ramforum.com/threads/air-suspension-troubles-fixed.204831/#post-2876095
If you do that and still have the message show up on your evic at startup, in AlfaOBD you need to connect to the IPC (instrument panel cluster) and clear the fault. But first do the steps listed in the thread I linked.
I think there's another app, JSCAN you can try with Apple, but I've never used it. You need an OBD code reader with bluetooth for either app.
Cheap android tablet or old windows PC + AlfaOBD + OBD2 reader is what you need.
