Recommended Jack for 6" lift Truck
cdn cj
Canada
I learned the hard way that lifting from the bumper allowed droop and barely got the tire off the ground to get it off.
I’ve always strapped the axle to the frame before trying a bumper lift. Although my CJ has the flex of a dump truck …..
WY-Dave
Cheyenne, WY
6.7 CTD
Exhaust powered, had one in the Jeep, took a couple of tries but got it balanced with all 4 tires off the ground (advertised 31.5" lift). Gave it to a nephew when I traded in the Jeeps
stock photo
Ramo70
Ramo70
stock photo
Interesting and thinking dangerous at the same time. Have to make sure car does not flip over and the carbon monoxide when done, def outdoor use.
Marshall
Sk, Canada
2014 sport
Just a note on "Jack All's", farm jacks , they are a great jack on the farm for machinery and such.
But not for these newer trucks with all the plastic.
They will also kill you. School mate of the son was killed when he was under a car jacked up with one of these, No jack stands in use. the bases on these are not ridged and if you jack both wheels off the ground , it will pivot sideways and fall.
Bigdaddyii
My Ram is lifted 6” and the factory jack lifts it enough to change a tire. Also the factory 18” spare will fit on a front corner. Not pretty but enough to get my butt off the side of the road. Just stuff I tried when I got the truck to make sure I could self rescue with what was provided or know that I needed to upgrade.
