2023 Tradesman - Comfort Popup
Nephilim70
Alberta
Good day folks,
I keep having a popup every time there is a shift in temperature. This is with the system in auto. It is very distracting and I would appreciate a fix for it.
Anyone else have this and got it fixed?
Thanks all!
chri5k
USA
Diesel
Which radio model is that?
Administrator
Are you saying this happens when you change the temperature? or does it happen by itself when the temperature in the vehicle changes?
Does the pop up go away on it's own?
A lot of OEM radios when running AndroidAuto or CarPlay to have a pop-up while making climate control changes so the driver can easily see the system status.
N
Nephilim70
Alberta
Good day folks, This radio is a uconnect 5. The popup happens when the climate controls are in auto and seems to happen whenever there is a shift in temp. It could be attached to the CarPlay app as it is running. Would you know if this can be turned off? Appreciate the input.
