Fuel pump
fadetoblack188
Under half a tank my sender don’t work
And get a check engine light so need to replace the unit.
Anyone have luck with any of the after market brands?
What do you recommend
aszumilo
Las Vegas
I used the O'Reillys brand with a lifetime warranty. in my old 2004. Got about the same mileage out of them as the OEM original pump (~50k miles). Only issue I ever had was one of them the fuel gauge would only go to 3/4 full, when I filled up. It would read correctly after driving a few miles.
BenWade
Houston
Oops... I meant the Delphi (FG1354). I replaced mine a few years ago and it has worked perfectly.
