ClarkR
- Joined
- Jan 25, 2022
- Posts
- 22
- Reaction score
- 7
- Location
- Crawfordville, Florida
- Ram Year
- 2015
- Engine
- 5.7
2015 Ram 1500 Big Horn 5.7
Intermittent no start, single click, jump out of the cab, seconds later hear another second click from fuse box. Checked relays, reseated them. 12.4 volts at the battery. Changed the battery twice now 1 year apart of each other, no love. When finally fired up have 14.4Volts on the system, steady. Removed Alternator and battery from the suspect list.
Key fob turn ignition (hate it). I still have to jump the starter solenoid, but need second set of hands, spinal injury, can't solo test.
It will start in this state most time with my jump box, putting out 14.4 volts. Seems silly but...
Haven't changed any other stock parts out, just the battery. Suspecting starter (less likely) or ignition switch (high suspect).
