Front Upper control arms for 2" drop
Dilligaf-23
austin, tx
I'm needing to replace my front upper control arms. I have 2" spring drop on the front. What would be the best but reasonable priced option out there. I would love to do the adjustable from core 4x4, but a little out of price range.
Dilligaf-23
Dilligaf-23
austin, tx
If you are only down 2 in the front from springs, I would suggest mevotec from rock auto as a lower cost option
would that help with the 2" drop or is it OEM spec? I'm hoping to find a control arm that would help with camber also
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
Mcginnis
Forney, TX
I used the Maxtrac ones with no problem. I’m about 2.5in lower in the front and have perfect alignment
