Can someone tell me what this cable does?
The security gateway bypass cable is used to bypass the security gateway module installed in all 2018 and later Ram trucks.
This security gateway prevents access to truck modules such as the Body Control Module (BCM) where options are available to be customized by the user.
Many of the security gateway bypass cables must be connected directly to the Security Gateway Module and then removed before visiting a stealership.
If the SGM is buried behind the radio or instrument cluster like gen 4 trucks, that's a huge PITA.
AFAIK, all gen 5 trucks have this module behind/beside the OBD2 port which isn't too difficult to access.
The big advantage of using the KaodTech Security Gateway bypass cable is that it connects to the Can bus blocks behind/beside the OBD2 port on gen 4 or gen 5 trucks.
Also, when you use a KaodTech cable, you have the option of not modifying the OBD2 port and the stealership can still make of it.
This also allows you to leave the KaodTech cable permanently installed.
I leave mine installed and tucked up under the dash.
