moist_oyster
I replaced my blend doors about 2 weeks ago. After putting everything back together and topping off the coolant (with heat running) with a radiator fill funnel to bleed out all the air, the temp needle will stay slightly below the center when it would stay solid in the center before at operating temp. I've put the radiator fill funnel on there twice now just to make sure I've bled all the air out and as far as I can tell there's no air left in the system. The temp will now hover around 202-204 Fahrenheit. I didn't change the thermostat and the overflow tank has an appropriate level of fluid.
Is this even a problem? There's no issues with trans or oil temp.
