hummus_daddy
Hey guys. 2014 Big Horn 8.4 with Nav.
Before you yell at me to search, I have and haven't found a solution to the specific problem I'm having. I've searched hundreds of threads, asked in Facebook groups, etc.
Every once in a while (becoming more often), my radio has a delayed start up. Sometimes 30 seconds, sometimes it's 10 minutes. Every time this happens, it seems to take some time remembering where it was and reconnecting the Bluetooth - like, the difference between putting a PC to sleep and powering it off completely. After it finally loads up, it stays powered on and works just fine but, it's rather irritating.
- I went into the settings and did a factory reset - nothing.
- Did the "secret developer menu" by holding the cold and hot AC buttons - reset, but still happens.
- I disconnected my battery and my ECU for an unrelated issue but that still didn't fix anything.
I also get a "Vehicle Phone Requires Service - Please See Dealer" notification frequently, my navigation can't locate me and doesn't work and my EVIC compass just goes in circles - not sure if this is related but I believe they came about at the same time (I don't use my factory navigation anyway).
Thanks in advance!
Thanks in advance!
