I have a 2016 1500 and have codes C2200-49 (ABS Module) and C0020-01 (ABS pump motor control). I've been doing a ton of research on this and have found that the pump motor on the Heavy Duty Rams has a very common issue where one or both of the brushes get stuck and cannot make contact. I have...
About a week ago my ABS lights came on, Pulled the code C2200049 ABS controol module internal electrical failure.
Facts :
Recently put new tires on rear move one of the rear tires to the front. 3 weeks prior to ABS failure .
Battery went bad - had it replaced , no change
I’ve done a break...
