abs module
  1. M
    ABS Pump Motor Repair for 1500
    I have a 2016 1500 and have codes C2200-49 (ABS Module) and C0020-01 (ABS pump motor control). I've been doing a ton of research on this and have found that the pump motor on the Heavy Duty Rams has a very common issue where one or both of the brushes get stuck and cannot make contact. I have...
  2. B
    ABS blinking and chiming
    Hey All, was hoping to get some help from experienced voices. I've got a 2002 RAM 1500. The ABS light constantly flashes and dings throughout all trips. If I take the fuse out, the dinging and flashing stop, but I get a consistent ABS/Brake light displayed. The ABS system seems to work fine, and...
  3. Rammered
    ABS MODULE programming question?
    I'm in the process or repairing a 2018 RAM 1500 ST. 5.7 it was destroyed, It runs and moves. I drove it off the truck to garage. The Shop i bought it from says they had to replace the ABS module cover, I hooked up my scanner and I get a Vin mismatch on ABS. Makes sense. The Donor truck was the...
