*first post*
I just installed two kicker cvt 12” on a kicker cxa 800.1 in my 2016 ram 1600 big horn 4x4 I got last weekend, using the pac ampPro device. And it sounds like pure D ****! The bass is muffled and no matter what I do I still kinda get highs coming thru my subs. And when I turn it up...
Here's what I got that I want to eventually go into my 2006 ram 1500. I have a Pioneer FH-S52BT, 2 10" kicker subs, and a 1000W Jensen amp. I am currently having issues hooking the Pioneer FH-S52BT and I am thinking it is the wiring harness that I bought from amazon which is the RedWolf harness...
Good morning all!
I’m new to the ram forum family. I am having an issue and read through a bunch of dsr1 forums but didn't see the issue I was having.. here is what I have: 2019 ram classic with the 6-speaker system and the 5” uconnect radio. I upgraded the factory system with kenwood excelon...
Trying to pinch some pennies so got into a Tradesman 2013 Ram 1500. I'm going to be replacing the factory radio with an aftermarket radio. Is there any way to install steering wheel audio controls with an aftermarket radio? So far, my research has told me no. Thoughts?
2017 ram 1500 express with 5.0 radio. Want to replace with new pioneer double din. All my settings for my truck go theough the radio. Anybody know what harness i need and do i have to huy the expensive nex model radio
I have to finish my speaker install by drilling new holes for the speaker mounts [stock were 3 point, new duds are 4-point] and this vapor shield will prevent me from reaching back and putting a hex key in the bolt to hold it in place while I tighten the nut down from the other side.
Now, I...
