So I have led dual headlights in my 2011 with antiflicker adapters and they’ve been working fine for that last couple months. All of the sudden I’ve lost my high beams and when I go to use them neither one of my high beam lights come on and my actual low beams cut out as well. The high beam...
Having a problem with the multi-function turn signal/wiper/washer/ high beam switch on my 2014 Express. Switching from low beams to high beams it signals the wipers to make a single pass across the windshield. It seams to be getting worse and more annoying. It started out doing this about every...
Can someone please tell me how to connect led pods to my high beams on my 2015 ram 1500 quad head lamps. I’m doing the projector retro fit from led concepts an I want to use a pod as my high beams but I want them to come on when I turn the high beams. Such as a specific wiring harness I can use...
