I bought a new 2019 1500 Tradesman Crew Cab 4WD in June 2020. It's "work truck" for me to use to carry my 2 Doberman Pinschers camping in the southeast National Forests. I didn't even keep the back seat in for years. I have a screw in a front tire and of, course, rather than plug the tire...
So I’ve seen some places say that adding a lift kit to your truck will void your warranty. Or you can purchase/have dealership install the Mopar lift and it doesn’t void anything(definitely not doing that cause it’s OUTRAGEOUS.) I mean I just bought the truck last year, I still have a long time...
I am looking to lift my 2015 EcoDiesel 2.5 to 4 in.
I want a solid suspension lift that will sit level in the front and back. Plan to put 35 x 12.5 with 17s on it.
Example: I know some are 2 in. in back and 4 in front. Should this sit pretty level. Any suggestions? Attached an image of what...
Im looking to getting the Maxtrac 7in lift kit for my 2wd ram. Im looking at a lot of reviews but some mention the need of wheel spacers in the rear? Is this true? Also someone recommended that I get new upper control arms if my truck has high mileage. Any advice on any of this. Im on a budget...
Hello to all
I am toying with the idea of lifting my truck I own a 2016 RAM 1500 Lonestar 5.7 Hemi 2WD. I first have to figure out the tires, but I would like to know your opinion on what would be my budget friendly options for at least a 2" lift, without compromising on quality and performance...
I installed an adjustable track bar on my 2003 Ram 3500 4wd to center the axle with the truck after a level lift. I installed it a few years ago after the bushings went bad in the newer style non-adjustable track bar (newer meaning it wasn't the old death wobble bar).
Well, my bushings were...
so ive recently gotten into a bit of a wreck and figured right now would be the best time to go ahead and make my long awaited dreams come true. So to cut to the chase I’ve been wanting a 6” lift along with some nice meaty rims and tires although I’m not trying to ‘break the bank’ either. The...
