So my wife and kids got me some new headlights for my 2014 2500 Laramie longhorn.
The lights that they bought me are Dodge Ram 1500 2500 3500 Black LED Bar Plank style Headlights pair part number is cs306-b10pa-7v
The problem is I already have factory projection headlights. The connection...
I read that the stock Infinity amp is an 8 channel, leaving one open channel...
Does anyone know if there's a way to connect to this channel and run it to another amp (either using a LOC or a sub with high level inputs) so I can add a sub without having to replace the factory radio or tap into...
So I know these things aren't the most accurate in general, but I read somewhere that when you don't reset the trip ODO each time you fill it becomes less accurate.
Do you agree with this statement? If so why does not resetting it affect it like that?
Mine seems to be reading 3/4MPG high...
I have a new '22 Ram with the 6.7 Cummins with 13K miles on it. It has been in and out of the shop for the last few weeks for a check engine light. The code refers to regen issues. The mechanic says it is a regen issue and asked how I used the truck (like I needed to not use it too hard). He...
