Freezzman
My problem is the overhead lights wont turn off. The dome light works as it should, turns off when the door is closed.
Their is power on the door sense wire when the door is closed which is causing the lights to stay on.
I must admit that I caused it. I tried to connect a dash cam to it. every thing seemed Ok when I removed the dashcam.
This morning the overhead lights were on.
Thanks for your help.
