Looking back at this data, the sensors are telling the computer it's running way lean, so it's adding a boat load of fuel, that's why the LTFT are so high. The STFT will bounce back and forth. I bet if you watch them enough they'll bounce back over to the high positive side quite a bit. Otherwise, the LTFT will start to back down.
Those anti-foulers are 110% contributing to the lean faults and the excess fuel being loaded into the cylinders. Read up on how they work. Seriously, pull them, throw them out, reset the PCM and start over. Bad data is going to give bad information. And that's exactly what's happening with those installed.
