Have you tried to continually press the cold button until the AC gets cold (regardless of what the screen says)? On my upgrade, I have to press the temperature button about 15 times after it has reached the bottom or top to get max cold/heat.i upgraded from a 5.0 to the 8.4 my truck is a single zone and i got a dual zone bezel can i change this with alpafa obd ? just need help i have no cold ac now it just blows hot thanks
I gave this a try and still no cold air and when I go to the 7th speed it stops blowingHave you tried to continually press the cold button until the AC gets cold (regardless of what the screen says)? On my upgrade, I have to press the temperature button about 15 times after it has reached the bottom or top to get max cold/heat.
Yes and No.i upgraded from a 5.0 to the 8.4 my truck is a single zone and i got a dual zone bezel can i change this with alpafa obd ? just need help i have no cold ac now it just blows hot thanks
I have a single zone and the only issue is what I mentioned and that is only with 2018+ UAS/UAQ radios.If I got a single zone I’d assume I wouldn’t have to go through all of that ?
Did you come from a 4 speed blower fan?If I got a single zone I’d assume I wouldn’t have to go through all of that ?
