ABS wheel sensor front passenger side line cut -- second time!
JSQuare
2019 1500 hemi 5.7, 2WD. A year ago the ABS light came on. Took it in, the wiring to the front passenger side ABS sensor was cut -- a clean cut. Okay, perhaps something somehow cut it. Now, the same ABS light. Back in, the exact issue again. Techs ran wiring as specified, checked to see if there was some pinch point/contact point and could not see one though noted the wire is at the max when wheel is fully turned. Anyone else run into this? The techs don't know what is what. Somewhat like when my gas tank suddenly would not fill any longer and when I inquired with Ram they replaced it for free. It seems something is amiss.
Daw14
Gotta ex that’s after revenge ? Fuel tank issue is common. Check out the search engine on this forum , top right , you can find common problems.
J
JSQuare
Tried that first, nothing relating this showed up. Nope on the fuel tank; happily married for over 30 years. Just a poor design that Ram re-engineered and Ram will replace it if you raise issue with how the hell a fuel tank won't allow you to fuel your vehicle. When you think about it, as Ram obviously has, it is an absurd proposition. Thus, when the ABS issue occurred twice and the techs cannot figure it, it is not a hard jump to think design issue.
