Wyatt Robinson
I applied rainx anti fog product to my interior windshield and now there are streaks and swirls that are very cloudy and hazy. What can I do to improve anti-fog properties of my 2017 RAM 1500 Sport HEMI?
Damn i'm old school yet Mike,i don't own a power polisher,i still do it the old way with grunt labour,lolHowever, carries some risk, diminishing abrasives can leave scraps. So I would use a low cut formula like IP, but not a finishing polish that uses oils. I would first test it on back windows behind driver, just to make sure. Low risk yes, but better safe then sorry.
The defrost setting will turn the compressor on automatically. In winter I start with hot air then adjust down, but cold can work as well. Just have to play with temperature settings for your specific conditions.Cold setting with AC on high?
Most vehicles when you use the defroster setting, uses the A/C to remove humidity and defrost. It does this automatically and turns on the compressor.I never needed ac, for me I just use cold setting on fan without ac, but ac is worth a try as well.
Interior outgassing is a huge factor too.Those products are known for that, the hardest thing for detailers to do is interior windows. The problem is the film that grows over years from moisture and human sources that becomes part of the window. You can ask a local detailer if they do hot glass treatments, that was the best way to clean them back in the day. If not try dawn dish soap foam the old one not the new one and get it as squeaky clean as possible, and don't use that product. Finish it off with a good glass spray and micro fiber towel, I like invisible glass in the can not bottle. Dry heat from your defroster is the best way to defrost windows.
I do, too, except not with newspaper, which I reserve for its real value as a replacement for toilet paper.I clean my windows inside and out with invisible glass and newspaper. No streaking!
