benny68
2013 5.7 hemi with new lifters, head gaskets. Leaking coolant from passenger side and running hot. I put 2 gallons of coolant back in it. Driver side seems fine. Any idea?
Odds are you installed the head gasket wrong,as they'll leak coolant from between the block and heads if the gasket is installed wrong.Pretty common issue for alot of guys on their first cam/lifter job on a hemi2013 5.7 hemi with new lifters, head gaskets. Leaking coolant from passenger side and running hot. I put 2 gallons of coolant back in it. Driver side seems fine. Any idea?
Wouldn't the right side leak too? Going to pull it back down and check. ThanksOdds are you installed the head gasket wrong,as they'll leak coolant from between the block and heads if the gasket is installed wrong.Pretty common issue for alot of guys on their first cam/lifter job on a hemi
the gaskets will be stamped left and right Left is drivers side right is passengerWouldn't the right side leak too? Going to pull it back down and check. Thanks
