LDay17
I have 2017 ram 1500 3.6, I have replace spark plugs and check engine light came back on for Misfire on cylinder 2. What else could be the problem, MAS air flow sensor is good.
I don't think that's as common on the Pentastar is it?If you’re lucky, bad coil.
More than likely though, Wiped cam lobe and lifter.
