peterz56
Hi!
My 2016 Ram 1500 has a TS issue. With the headlight switch turned off and going a few minutes down the road i get a dash note saying the RT front blub is out and stops working but when you turn the parking or headlights on first thing the bulb always works. 2 years ago i installed a set of LED amber lights on the grill that are tied into the parking and ts bulb and the right leds will not work either when the bulb note comes up the dash. Bulb socket is good, all the wiring is ok well into the harness. I'm not sure where to look next. Frustration is starting to set in because i hate chasing down electrical problems. Any help would be appreciated. Thank you in advance.
Peterz
Peterz
