Yowkati
So as of two days ago my truck was relatively fine (pep boys debaucherized my power control arm and rotors currently pursuing legal options as theyve made a “complementary repair” to their previous repairs 7 times since February its actually foul but ill spare you from what that looks like)
So i was out with a girl and we got distracted (netflix and ramming) and long story short i forgot to turn my car off for like 3 hours when i go to jump it with a box that was on 75% charge nothing ended up being able to use my apparently dead battery to charge it to 100 and my phone and have ac still unable to jump it ended up having to buy a whole new box the next day luckily was parked at a walmart anyway and was able to jump it with that one than got “home” (its a 45 min drive from this walmart to my house) turned my car off and figured it was the box being low on battery or something weird i honestly was so tired i just went to sleep woke up and went out to start my truck nothing try jumping with new full box nothing get my buddy to bring me my trickle charger he was using it charges all day plug it in nothing jump it with the new box on full success
However once i got in my truck i noticed that every light on my dash that could be on was my speedometer was no longer working yet my rpm is i have turned my car off twice since that and only for minutes been driving around for 3 hours now am currently back sitting at a different walmart after getting my battery tested n it coming back healthy same with starter n alternator checked my obi2 reader and saw that i was suddenly throwing
Out of literally no where im unsure about what my next steps should be i bought a new tipm when i got her in November and have fully changed out my fuses
I read that the fuel pump relay inside the tipm could be my problem and that i could bypass it with some simple stuff from autozone so im going to try that but i also wonder if it could be specific modulesof my tipm or my power control module itself the wires are frayed looking but all getting power save my left blinker n left brake light but i figured out my problem there and repinned it last night while trying to figure out what was wrong now i also finally discovered what this little white knob as below is (not in manual and no mechanic could figure it out) it was this stupid little relay that hadnt been connected since i bought it hooked it up and suddenly wow fog lights anyway here all my pics please for the love of all things holy please help i live in the damn truck its literally my house i got it converted to a camper in the back any guesses or insight would be appreciated
| U110C Lost Fuel Level Message | V | |
| U0141 | Lost Communication With IPM (FCM/TIPM) | ^ |
| P0463 Fuel Level Sensor 'A' Circuit High | ||
| U1403 Implausible Fuel Level Signal Received | ||
| U110E Lost Ambient Temperature Message | ||
| P0456 Evap System Small Leak |
| B1A25 Invalid Key | ||
| V | 6 Front Control Module (Central Gateway) Codes | |
| B1648 Rear Right Turn Lamp Control Circuit High | ||
| P127E Fuel Pump Control Circuit 2 Open | ||
| B1669 Reverse Lamp Control Circuit Open | ||
| B1644 | Status: PENDING - Rear Left Turn Control Circuit High |
| B2213 | Status: ACTIVE - Cabin Compartment Node/Cluster |
